roof slope across two directions
Tracey Sharples
Is it possible to slope a roof (or any other tool) across two directions - so front to back but also side to side? I can only get a single plane roof to slope in one direction. I'm using SE18.
Thanks
Archicad 26 Win11
7 REPLIES 7
Lingwisyer
Guru
As in pitch and yaw?
Tracey Sharples
I have never heard the term yaw before, but after looking it up I think that is what I mean.
Archicad 26 Win11
Lingwisyer
Guru
Since the pitching line of a roof must be level, you effectively want a roof that has a pitch that matches the intersection of 2 roofs, matching your two slope amounts. Draw a multi-pitch roof. Modify the pitches of two adjacent sides to have your two slope amounts. Draw a single-pitch roof perpendicular to the intersection of the two sides that you modified.
The Beam tool has a sloped and profile rotation option. Cannot remember if the option was there in AC18 though... Though this would be pitch and roll and you would have less control over the overall shape.
Ling.
Search the posts in this forum or look in the user guide or help center for modelling a roof in 3D.
Tracey Sharples
Thank you!
Archicad 26 Win11
TracyGA
Curious if you ever got this to work?
Lingwisyer
Guru
Barry outlined a easy way to do this in 3D a few years ago in this post.
Ling.
