rotate column
fa furrukh
I have a problem, I did not rotate Column from one side, I already snap bottom with point cloud , but top side out of cloud , I want to rotate on top and match into point cloud , how I rotate one side or other tool for snap both side top/bottom ,
1 REPLY 1
You can rotate a column about its axis by dragging the corner nodes, but that will rotate the top and bottom the same.
You can lean or angle a column (which I think is what you want) by dragging the axis top or bottom.
