Design forum
show opening lines in 2D but not 3D
heathldesign
hey everyone,
can some please tell me how i display opening lines for doors and windows in 2D elevations, but not in the 3D rendering?
iMac 27" i7 4 Ghz osx 11.5.2
AC 25, 3002
5 REPLIES 5
Eduardo Rolon
You will need to define 2 MVO's (Model View Options) one for Elevations and Sections (Opening line ON) and another for renderings (Opening line OFF).
eduardo rolón AIA NCARB
Another of the forum moderators.
Macbook Pro 2.4 i9 32GB ram
OS X 10.XX latest
AC25 US/INT -> AC08
heathldesign
i've tried that. i went into the MVO dialog, selected 3D renders and then went all the way down to the bottom under miscellaneous settings for library objects and deselected the "opening line in 3D" for windows doors and SK. made sure my 3D view MOV is set to 3D render and the opening lines are still showing. is there another step?
AC 25, 3002
Are the objects set to use the MVO settings?
They can be set to ignore the MVO and use their own settings.
Versions 6.5 to 25
heathldesign
that was it. very counter intuitive and a bit confusing. create MVO for the two options, then set each object opening lines to override MVO or not, and then set the object detail level by MVO or not. I hope i remember this.
AC 25, 3002
Eduardo Rolon
Basic Rule are: [list=]
  • MVOs control is a global control that is saved with Views. Create os needed for different types of Views
  • [list=]
  • MVO Overrides are object level exceptions that will ignore the global settings
    So as a rule you never Override as long as you can control with a Global setting like MVO, Layer COmbination, GO, Scale, etc.
    OS X 10.XX latest
    AC25 US/INT -> AC08
    Didn't find the answer? Start a new discussion
    Labels
