special menu option in 9
I have gone into the reg edit file and changed the special menu option from "0" to "1", but when i reload archicad the menu is not there, it is also not in the customize menu area.
any help.
any help.
Do a Search of the forum. We talked about this at length already, and I gave screenshots. You need to go into your Work Environment and add the menu after enabling it.
One of the forum moderators
Check out Karl's how to thread - here
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
Thank you, that works great.
I had done a search, but did not find that thread.
