Parametric design
About Rhino & Grasshopper and PARAM-O.
story view
I've created some columns in grasshopper and then i connected the grasshopper to Archicad. the columns height are up to third floor but I can see them just in one story view according to the home story input in columns setting component in grasshopper. I've given multi stories to home story input i don't receive any errors, but I cant see them in the selected views, it seems like it doesn't work for multi stories simultaneously. If I'm wrong I will be so grateful if any one help me solve the problem
1 REPLY 1
Hello m_aalaei,
If you tell your columns to cross more than 1 level you have to modify them to have a right plan representation. This is one of archicad basic parameters. You don't need Grasshopper to link columns to another level. Why do you use Grasshopper ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Learn and get certified!
