2018-05-04 05:23 PM
Solved! Go to Solution.
2018-05-05 12:56 AM
ArchiCAD 25 6000 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
2018-05-06 08:33 PM
RWARCHPC wrote:Out of curiosity, I downloaded and tried out the USA ceiling accessory provided as part of ArchiPlus. (You also need the standard Accessories Goodies, as it's a slab accessory.) It works just fine in v21, and is very simple. It's not a true 3D solution, but gives you adjustable grid lines on the bottom of a slab (and plan), where all of the intersections are snappable. Throw some of the GS standard 3D troffers in there and I'd say it looks pretty darn good and is not likely to cause file bloat. I'm not sure why people are saying it's not supported in v21.
Can anyone make a suggestion for modeling and documenting a commercial suspended ceiling system in ArchICAD 21? I have read other posts here that seem to indicate that the ceiling editor / v21 is no longer supported .
2018-05-07 09:26 PM
2018-05-28 05:53 PM
2018-05-28 06:55 PM
2018-05-31 01:57 AM
Subject | Likes |
6 | |
4 | |
3 | |
3 | |
3 |
