transfer cabinet properties
Dave Brach
so let's say I have a base cabinet with all the properties that I like: surfaces, counter overhangs, knob type, kick plate inset, etc. How do I transfer those properties to a different cabinet object: say, from a Base Single Door 24 to Base Corner 24? I have tried to use the method that I have with windows, where I extract with the eye dropper then inject into the library part but it does not seem to work.
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
1 REPLY 1
Are you doing the Parameter Transfer in the Object Settings Dialog?
1. Pick up the parameter from a Cabinet placed in the Project.
2. Go to the Object Settings Dialog.
3. In the tree structure on the left, navigate to the folder in which the Corner Cabinet is located so you see it in the bottom left area. CTRL-ALT -click the Corner Cabinet object to activate it in the Settings Dialog and transfer picked parameters to it.
Learn and get certified!
