Design forum
transferring attributes from favorites
Dave Brach
I have a model of a house with 20-30 various windows. I'd like to transfer the attributes of one of my window favorites (surfaces, jamb/sash dimensions, wall connection etc) onto all the windows at once but without changing the the current sizes or locations of the windows. Is there a way to do this? Thanks!
Dave Brach/architect
Salt Lake City USA
www.brachdesign.com
AC24 MBP OS Catalina 10.15.7
2.6 GHz 6core intel core i7 16 GB RAM
Radeon Pro 555X 4096 MB
Intel UHD Graphics 630 1536 MB
Braza
You can define a specific Element Transfer Setting for this.
First: unselect all options. Then go to the Door/Window option and select only the parameters you want to transfer.
Hope this helps.
Paulo Henrique Santos, Architect
AC24_INT#3008 / I7 / 16Gb / 512Mb SSD / Windows 10
I am not sure modifying Element Transfer Settings will solve this. We are talking about Library Part parameters here, and Element Transfer Settings are not granular enough to accommodate this. You cannot define a specific selection of Library Part parameters to be transferred.
What you can do is you can memorize the parameters, or you can create a screenshot of all the parameters you want to transfer. Keep it in an image editor for reference.
Then select all Doors your want those parameter settings transferred to. Then simply set those parameters to the same values based on the reference screenshot.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Didn't find the answer? Start a new discussion
