I am not sure modifying Element Transfer Settings will solve this. We are talking about Library Part parameters here, and Element Transfer Settings are not granular enough to accommodate this. You cannot define a specific selection of Library Part parameters to be transferred.
What you can do is you can memorize the parameters, or you can create a screenshot of all the parameters you want to transfer. Keep it in an image editor for reference.
Then select all Doors your want those parameter settings transferred to. Then simply set those parameters to the same values based on the reference screenshot.
