wall/roof by face in archicad
There’s a panel in Revit named massing and site that we can create complex forms with it. , and then we can add walls and roofs to the surface of the conceptional form.
In ARCHICAD we can create complex forms with morph tool, but how can we add walls or roofs to it or how can we convert them into composite elements ?
the problem is that when we use morph, its just one solid element however in reality a wall or roof has several layers.
for example (structure layer , thermal layer, finish layer ).
I would very much appreciate your comments.
There is a workflow using Grasshopper using which it is possible to achieve this.
You can use the Deconstruct Morph component to get the surfaces of the Morph, then you can generate Walls, Slabs, etc. based on those geometries.
4 REPLIES 4
thank you very much for your reply
dear Mr.LaszloNagy,
I'm currently working with AC-Gh connection. although its very efficient in many aspects but I still have problem with the subject I mentioned in topic. there is only one way to create a wall in AC_Gh connection and that is wall by curve. I cant give a surface or a boundary as input to a wall. also for slabs it works only with horizontal plane.
Well, that is what is possible to do with the current capabilities of the ARCHICAD-Grasshopper Connection.
Yes, Revit has this capability that you can take a face of a Mass and create a Wall based on it, but Revit is capable of creating generic double-curved Walls, so it can do that.
ARCHICAD does not have that capability so it is not possible to create Walls using this method.
My guess is that it will stay that way for the foreseeable future.
