2019-07-03 11:36 PM - last edited on 2023-05-23 02:09 PM by Rubia Torres
Solved! Go to Solution.
2019-07-07 05:17 AM
2019-07-07 05:17 AM
2019-12-20 11:01 AM
2019-12-20 11:16 AM
LaszloNagy wrote:dear Mr.LaszloNagy,
There is a workflow using Grasshopper using which it is possible to achieve this.
You can use the Deconstruct Morph component to get the surfaces of the Morph, then you can generate Walls, Slabs, etc. based on those geometries.
2019-12-21 12:36 PM
