window ID in elevation view.
Hi
I wonder IF there is a way to be able to se the window ID in elevation view.
Every time the office do a project we have to spend time texting in the correct ID in all the elevations.
2 REPLIES 2
David Maudlin
nori0003:
You can use the Label Tool in Elevation to label the window and show its ID.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
...to clarify: David is talking about using the Label Tool as an associative label... it picks up the ID of the window/door "live". This label in elevation is independent of an associative label in plan, etc. (The label tool can be used as an independent/text label too... which would be the same as what you're doing now, nori0003.)
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Learn and get certified!
