Archicad C++ API
26 Dev Kit Missing Solution and/or Project Files
Ben Cohen
Hi
I have installed the v26 Dev Kit. 26.3000
All the example projects are missing the .sln files.. this makes it pretty much un-usable.
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
poco2013
Mentor
The developer kit now uses CMake to generate those files as  necessary to use VS and to compile.
See the CMake blog on the developer's Site. Works OK.
Gerry
poco2013
Mentor
Gerry
Ben Cohen
Thanks Gerry.. looks like I have some reading to do 👍
Ben Cohen
Mac and PC
Are you talking about this blog?
I don't know what I should do.
I'm a beginner, so please explain.
I am going to start studying api in Archicad 26.
GitHub - Graphisoft/Archicad-addon-cmake: CMake Template for Archicad Add-Ons.
AC27 on window 11
