Archicad C++ API
2d wardrobe symbol
bouhmidage
My gdl skills are almost equal to 0,
In the Archicad library there is a 2d symbol ofca rectangle and a cross inside of it,  that can be used for wardreobe  2d representation
Can someone please script an object that can do this, but instead of a rectangle, the shape can be edited,
In3d, the object shows the volume with a given thickness, and that volume can be repeated vertically to a given number with a given distance,
Thanks
Archicad 25
Windows 10 professional
12 REPLIES 12
Lingwisyer
Guru
Edited to what extent? Still a rectangle?
And I do not get your 3D point or your 3rd drawing...
bouhmidage
Here are screenshots to explain better,
Archicad 25
DGSketcher
Legend
Why does a slab not do the job, can you explain how an object would be better? I can't see any major benefit to it being an object, in presentation the doors are likely to be shut or the shelves easily duplicated. For quantities it would just be a single object, where a slab can be easily counted etc.
bouhmidage
an object can be parametric, each wardrobe have a number of shelves that can be edited,also, shelves are combined in a single object that can be handled easily without the need of grouping slabs and managing them all together,
for quantitiy takeoff, from an object i can extract :
1 - number of shelves, for that specific wardrobe
2- Area of shelves of that specific wardrobe,
Archicad 25
DGSketcher
Legend
@bouhmidage This is one for the GDL experts... Extracting the number of shelves is easy, but I'm not aware of an easy way to pull the surface area of a random polygon shape in the standard GDL commands.
bouhmidage
maybe using a composite Slab ( alterning wood and air space ) would be better in this way,
or using a simple  slab, with 2 properties : shelves count , shelves area ( a formula : shelves count x 1 shelf area )
Archicad 25
It's not the modelling that is difficult, it's the maths to calculate the area of a random number of points. I'm sure there are some users round here that would solve that in a few minutes but it's beyond my skill set.
This is true, i have spent many hours trying to write algorithms to calculate the areas.
however there is a way to calculate the total shelf area, But its more or less a hack.
you set the shelf thickness to .001 only in the schedule which will allow you calculate the material area with basically no thickness.
bouhmidage
in this case this can be helpful !
the object is used for 2D representation and calculations, no need for the thickness , to represend thikness in section you can just use a thick pen ,
Archicad 25
