2022-03-20 09:31 AM
My gdl skills are almost equal to 0,
In the Archicad library there is a 2d symbol ofca rectangle and a cross inside of it, that can be used for wardreobe 2d representation
Can someone please script an object that can do this, but instead of a rectangle, the shape can be edited,
In3d, the object shows the volume with a given thickness, and that volume can be repeated vertically to a given number with a given distance,
Thanks
2022-03-21 07:26 PM
Oh it would still have its thickness everywhere else just not in scheduling so that you could get an accurate reading of the top surface area of each shelf
2022-03-23 09:03 PM
Hello.
If I understand correctly what you need, this is relatively easy to achieve, including the area calculation (as long as there are only straight segments). You can use the object I posted here to start. You will need to make a few modifications so you can build the array that models the shelves, but it has what you need to get you going.
Hope this helps.
Best regards.
2022-03-25 08:05 AM
That Area of an Irregular Polygon is pretty neat. Why did we not get taught that in school... Pretty neat and uncomplicated math.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
