At the beginning of the script you need to 'DEFINE STYLE' to set the values for the font you want to use.
DEFINE STYLE "name_string" font_family, size, anchor, face_code
Then just before the TEXT2 command you have to 'SET STYLE' to use it.
SET STYLE "name_string"
You can define as many fonts styles as you want (all with different names) and then set them just before you want to use them.
The font_family, size, anchor, face_code variables can all be parameters so that your user of the object can change them in the object settings.
