2018-08-25 01:09 AM - last edited on 2022-11-30 10:45 AM by Daniel Kassai
static void Do_ExportWallsToExcel (void) { DBPrintf ("Exporting walls to Excel document...\n"); libxl::Book* book = xlCreateXMLBook (); libxl::Sheet* sheet = book->addSheet (UNISTR_TO_LIBXLSTR (GS::UniString("Walls exported from Archicad"))); libxl::Font* guidFormatFont = book->addFont (); guidFormatFont->setSize (6); guidFormatFont->setColor (libxl::COLOR_GRAY50); libxl::Format* guidFormat = book->addFormat (); guidFormat->setFont (guidFormatFont); GS::Array<GS::UniString> titles; titles.Push ("GUID"); titles.Push ("Height"); titles.Push ("BeginCoordX"); titles.Push ("BeginCoordY"); titles.Push ("EndCoordX"); titles.Push ("EndCoordY"); for (UIndex i = 0; i < titles.GetSize (); ++i) { sheet->writeStr (0, i, UNISTR_TO_LIBXLSTR (titles)); } GS::Array<API_Guid> apiguids; ACAPI_Element_GetElemList (API_WallID, &apiguids); for (UIndex i = 0; i < apiguids.GetSize (); ++i) { GS::Guid gsguid = APIGuid2GSGuid (apiguids); API_Element element = {}; element.header.guid = apiguids; GSErrCode err = ACAPI_Element_Get (&element); if (err != NoError) { DBPrintf ("ACAPI_Element_Get returned error (%d) for GUID '%s'\n", err, gsguid.ToUniString ().ToCStr ().Get ()); continue; } API_WallType& wall = element.wall; //DBPrintf ("GUID '%s'\n", gsguid.ToUniString ().ToCStr ().Get ()); sheet->writeStr (i + 1, 0, UNISTR_TO_LIBXLSTR (gsguid.ToUniString ()), guidFormat); sheet->writeNum (i + 1, 1, wall.height); sheet->writeNum (i + 1, 2, wall.begC.x); sheet->writeNum (i + 1, 3, wall.begC.y); sheet->writeNum (i + 1, 4, wall.endC.x); sheet->writeNum (i + 1, 5, wall.endC.y); } IO::Location location; IO::fileSystem.GetSpecialLocation (IO::FileSystem::UserDocuments, &location); location.AppendToLocal (IO::Name ("export.xlsx")); GS::UniString filepath; location.ToPath (&filepath); DBASSERT (book->save (UNISTR_TO_LIBXLSTR(filepath))); book->release (); DBPrintf ("Export operation finished\n"); }
Solved! Go to Solution.
2018-08-27 10:56 AM
IO::Location location; IO::fileSystem.GetSpecialLocation (IO::FileSystem::UserDocuments, &location); location.AppendToLocal (IO::Name ("export.xlsx"));Don't you find the "export.xlsx" file in you documentation folder after executing this operation?
2018-08-27 10:56 AM
2018-08-28 09:15 AM
2018-08-28 09:42 AM
park wrote:I'm glad that you solved the issue and you can continue the AddOn development!
2018-08-28 07:31 PM
Tibor wrote:This is an excellent reason for anyone posting here in the Developer Forum to make clear if they are experimenting with the API using ARCHICAD in Demo mode - or if they have an API license key and are testing in a production license.
Yes, you're absolutely right. The code inside DBASSERT runs only if you built your AddOn using Debug configuration.park wrote:I'm glad that you solved the issue and you can continue the AddOn development!
2018-09-11 12:13 PM
2018-12-01 07:01 AM
park wrote:I get the following errors when the change mentioned is made, any suggestions why?
before
book->release ();
after
bool aaaa= book->save (UNISTR_TO_LIBXLSTR(filepath))
book->release();
After making the above changes, an Excel file was created in the Documents folder.
