Developer forum
Archicad 24 API & other announcements
Akos Somorjai
Folks,
The Archicad 24 API devkits is available on the API site https://archicadapi.graphisoft.com.
We have also created a landing page (https://graphisoft.com/downloads/python) for those who are interested in the capabilities of the brand new Python/JSON API. Please note that this approach differs from the previous experimental version in many ways, so make sure to go through at least the introduction section
Beside the well-known archicadapi@graphisoft.com email address you can also contact us via the new customer support service desk, https://graphisoft.atlassian.net/servicedesk/customer/portal/5. Please note that all email issues are routed to this portal as well, so even if you started with an email you may continue on the service desk portal.
On the personal side, I'm changing hats this year, being offered the greater responsibility of shaping the future direction of Archicad as a platform. That also means moving away from the day-to-day API support I've been doing for 22 years — anyone remembers API 1.3 in 1997 ? So, with some sadness I'd like to pass the steering wheel to Tibor Lorántfy and the developer support team to continue the tradition of giving the best help you can get.
Archicad API rocks!
Akos
10 REPLIES 10
Tomer1
great to hear! I didn’t understand some things:
1. Is the cpp API still has the most abilities? Or the python api already provides ALL the features that the cpp api offers?
2. What is the difference between Json api to python api?
Thanks!
Ralph Wessel
Mentor
My memory of the API - and having early training with you - go back to 1999. You've been instrumental to the development and support of the ARCHICAD API for the whole time - very sad to be losing you. But GS is gaining a steady hand for the future of ARCHICAD, and wish you all the best in that role.
Ralph Wessel BArch
Congratulations on the move up the ladder!
It makes sense that you have been offered this greater responsibility and the fact that worthy people such as yourself and Gergely get elevated in Graphisoft makes me love the company even more and gives me a lot of confidence in the future.
I hope to see you both again soon.
Cant wait to play with the new Python/JSON API! well done! again
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
poco2013
Tomer1 wrote:
Thanks!
Hopefully AKOS hasn't already left for his new position, but in the meantime - as I see it.
The C++ API is about the same with some new additions to cover the new features. The Python API is more limited now than even the experimental version, basically covering only properties and a little of the "navigator". It parallels,somewhat, the Property_Test example in the C++ API, but little else. However, it has a new format which is much easier to use and understand. Comparing it against the present Excel/properties capabilities, I don't see much advantage in using it. It has no capability to create or manipulate elements or labels/zones, at present. So basically useless.
Graphisoft has, however, mentioned that they are now working on modeling wrappers for Python and that they have the capability to update the Python API outside and independent of the annual revisions (see PyPi.org/archicad). This is true but remains to be seen. A continuous update philosophy would be welcome but I see no movement to solicit input from the users. Perhaps Python development has already taken a "left turn", that would be a shame since the work to date has been pretty good.
The Jason and Python API's are mostly the same thing. Json just allows one to package Python commands (API wrappers) in Json format (dictionaries) and forward to a running Archicad instance , thus one could use any programming language which supports Json and URL's to communicate commands to Archicad.
IOW, a good start but mostly a "marketing novelty". At this point. I'm waiting on management to define the direction and time line of Python before I commit to something with limited support and use.
Gerry
Windows 10 - Visual Studio 2019; ArchiCAD 25
Akos Somorjai
Thanks, Gerry, that mostly covers it. There are two main reasons why we started the whole Python development:
- automation requests from clients
- lower the entry to the Archicad API world -- Archicad itself is complex enough, so let's try to take away the complexity of the programming language by adding Python.
The C++ API is the major interface to Archicad and will be in the foreseeable future. The Python API exposes some (bigger and bigger) part of that functionality in a modern, Python-conform way.
The first step in Archicad 24 is the property interface and layout book generation, element access is coming.
The major difference between C++ and Python/JSON is that the latter is intended to be an automation tool, where you can drive Archicad from the outside, whereas the C++ interface allows much deeper integration (menus, user input, dialog boxes, etc.).
Best Akos
Ziv Abraham
The new Features sound great!
Do you know when will the python API will have the full capabilities of the CPP API?
And anyway, enjoy and have good luck on your next role!
Best Regards!
Ziv Abraham
Petar_Pejic
That is good news. Will it be possible to create simple dialog inside archicad via python scripts?
ArchiCAD 24
poco2013
It will be interesting to see if anything other than a vague answer is given.
My thoughts are that since Python has the add-on's of Tkinter and Qt5 which are much more versatile and powerful than Archicad's interface, it would be a waste of resources to try and duplicate the C++ interface?
Better to target more C++ function wrappers to expand Python's usefulness. However, I would like to see an interface (read/write) to the interactive schedules , the capability of which is badly needed.
Gerry
Petar_Pejic
I agree.
Regarding the schedules, I do not believe it is related in any way with python, I asked that question on beta forum and there was no answer given.
ArchiCAD 24
furtonb
I remember seeing an example script to create a Layout Book from Excel.
I think it was on the Developer blog written by Ákos or Tibor, but I cannot seem to find it now.
The GS website examples don't contain that one, if I'm not mistaken.
Could someone help me out where to find it?
actively using: AC22-25 INT | Rhino6-7 | macOS / win10
