I don't have time to check right now, but it is easy for you to see what is available - the schema are self-documenting.
Simply link all tables into a Microsoft Access project and view each table in design mode. If you see fields for coordinates somewhere, you're in luck.
Note! The schema used by the ODBC driver are not the same as those used by the SQL interface in the Calculate menu... so you do have to use the procedure above to see what is really available via ODBC.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
