BIMx API
About enriching BIMx with new capabilities using its API.
BIMx Developer ID
SajW
Is the BIMx Developer ID the same as the Archicad API Developer ID? If so should I use the DEVELOPER ID AS STRING or just DEVELOPER ID? If not where to get this ID from
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
Currently BIMx Developer ID is differ from the ARCHICAD Developer ID, but hopefully it will unified in the future.
Until that time please send an email to archicadapi@graphisoft.com to request Developer ID for BIMx.
1 REPLY 1
Tibor Lorantfy
Graphisoft Alumni
Graphisoft Alumni
