GDL
BUG Report: LP_XMLConverter tool
Nader Belal
Mentor
Hi there,
I think there is a bug in the LP_XMLConverter tool for ArchiCAD version 22.
IF you put a normal text in one of the 16 layers of a GSM file, and convert it to XML, you will be unable to convert it back to GSM, cause the the tool will generate an error message that it cannot identify the associated font that was used.
I also checked for the installed fonts on my PC and it was there.
Nader Belal
Mentor
Hello guys,
The issue have been solved and you can check this thread to know how to solve it
http://gdl.graphisoft.com/forums/topic/problems-with-lp_xmlconverter-tool#post-18596
1 REPLY 1
Nader Belal
Mentor
Hello guys,
