GDL
Can I skip the value from the label to mark it?
soo
Hi
I'm making a label for Finishing materials.
there is a problem to solve that I want to skip the value named AIR but i don't know how to skip it.
For example, in this picture Even if the slab contains 4 materials, I don't want to label the material named AIR.
this is the scripts i used.
for i = 1 to numText
if (fra(MATthk[n]*1000) > -eps and fra(MATthk[n]*1000) < eps) then
thk = str("%.0mm", MATthk[n])
else
thk = str("%.1mm", MATthk[n])
endif
autotxt[i] = "T" + thk + " " + MATname[n]
autoTHK[i] = MATthk[n]
I don't see how to exclude the value MATname[n] = "AIR" in the middle of this root.
Even if i force it to make it by removing the value, it was only marked as zero, but it was not completely removed.
I want only three expressions: AA, BB, and CC on my label.
Like this picture.
Please help me to solve this problem.
thank you.
I tried add some loop on script as someone adviced me before
but it still put "air" or "0" on the screen.
I want to SKIP the "air" line.
if numTextAdd = 0 then
if MATname[i] = "공기 공간" then
autotxt[i] =autotxt[0]
else
else
endif
if mirrorText = 0 then
n = n+1
else
n = n-1
endif
endif
next i
5 REPLIES 5
JP1
Hi Soo,
Can you show how you have generated the texts? I am thinking that you should control this where you generate text.
else
!!GENERATE TEXT!!
endif
You could also try utilising ID field of building material. For instance the ID of building materials you want to hide could be set to "-" and in the script you can request building material ID and set it to do nothing if ID is "-".
n = REQUEST{2} ("Building_Material_info",n = REQUEST{2} ("Building_Material_info", name_or_index, "gs_bmat_id", MY_MATERIAL_ID)
James
It looks like you need to convert your data to a string and then exclude it with an if statement should the string not match
soo
this is how i put the material name and material thickness.
if MATname[1] = "AIR"
then
else
else
endif
n = n+1
else
n = n-1
endif
endif
if numTextAdd = 1 then
if i = userTextPos1 then
autotxt[i] = userText1
autoTHK[i] = 0
endif
if i <> userTextPos1 then
else
endif
n = n+1
else
n = n-1
endif
endif
endif
if numTextAdd = 2 then
autoTHK[i] = 0
endif
if i = userTextPos2 then
autotxt[i] = userText2
autoTHK[i] = 0
endif
if i <> userTextPos1 and i <> userTextPos2 then
else
endif
n = n+1
else
n = n-1
endif
endif
endif
if numTextAdd = 3 then
autoTHK[i] = 0
endif
autoTHK[i] = 0
endif
if i = userTextPos3 then
autotxt[i] = userText3
autoTHK[i] = 0
endif
if i <> userTextPos1 and i <> userTextPos2 and i <> userTextPos3 then
else
endif
n = n+1
else
n = n-1
endif
endif
endif
if numTextAdd = 4 then
autoTHK[i] = 0
endif
autoTHK[i] = 0
endif
autoTHK[i] = 0
endif
if i = userTextPos4 then
autotxt[i] = userText4
autoTHK[i] = 0
endif
if i <> userTextPos1 and i <> userTextPos2 and i <> userTextPos3 and i <> userTextPos4 then
else
endif
n = n+1
else
n = n-1
endif
endif
endif
if numTextAdd = 5 then
autoTHK[i] = 0
endif
autoTHK[i] = 0
endif
autoTHK[i] = 0
endif
autoTHK[i] = 0
endif
if i = userTextPos5 then
autotxt[i] = userText5
autoTHK[i] = 0
endif
if i <> userTextPos1 and i <> userTextPos2 and i <> userTextPos3 and i <> userTextPos4 and i <> userTextPos4 then
else
endif
n = n+1
else
n = n-1
endif
endif
endif
next i
endif
i did that you wrote it before.
and now it shows like this.
if you know how to pass the "AIR" away,
please let me know
soo
Hello I want to remove a specific value from an array.
For example, if the Label object can show Material Thickness and Material name togeter.
I removed only the "air" layer to don't display it on screen.
I asked before twice in this board.
but the info i got last time, it just shows the value as 0, but I couldn't get rid of it.
i wanna make this label which can remove "AIR" row automatically.
I attach my file below.
plz let me know how to solve this problem
GDL doesn't have the equivalent of break/continue in other languages.
It would be simpler to add a condition where you are displaying the data with TEXT2.
Or you need to be creative with goto:
output = 1
for input = ...
    if MATName[input] = "AIR" then goto "nextMAT" ! skip input
    ! process input
    autotext[output] = ...
    output = output + 1
    "nextMAT":
next input
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
