GDL
Check box for integer parameter
Bruce
How do I have a check box on the interface when my parameter is an integer, not boolean?
It's a long story, but I have a 2-dimension array: column 1 is the story index, column 2 is 1 or 0 to show or hide.  Is there a simple way to display this second column as a check box option, or do I need to create another dummy array as a boolean?
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5003 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
4 REPLIES 4
UI_INFIELD{4} with a picture? see files
Mac OSX - up to date
GER Archicad Full, Up to date
DGSketcher
Legend
@Bruce Are you using the default parameter display or the Parameter Script to set the values?
Yves
two other possibilities
!!!!Master or Parameter Script
VALUES{2} "column_2" 0,"No",
1,"Yes"
!!!!!!!Interface script
UI_INFIELD{3} "column_2", 10, 10, 50, 15,
8, "", 2, 1, 0, 0, 0, 0,
0, "No",0,
1, "Yes", 1
UI_PICT_RADIOBUTTON "column_2", 0, "No",
"", 10, 50, 50, 15
UI_PICT_RADIOBUTTON "column_2", 1, "Yes",
"", 10, 70, 50, 15
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Bruce
Thanks guys.  I can't use the parameter script to set the values, as column 1 of the array isn't boolean.
I ended up creating another proxy array of boolean type, that copies its values into the first array when modified.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
