Archicad C++ API
Clarification: APIDevKit latest version for AC 20 (3012 or 3002)?
Erenford
Greetings, my team noticed a difference on the AC 20 SDK version on the new site (archicadapi.Graphisoft.com) versus the old site (partner.Graphisoft.com).
The old one has v20.3012 which we currently use, but the new one has v20.3002 as the latest version. Based on the number, the old one will be the latest one, but based on the upload date and the fact that its on the newer, non-obsolete source, v3002 is the latest.
Which version should we use? Should we stick to the old one or update to the new one?
Archicad 25 5010 INT FULL
Archicad 26 5002 INT FULL
Visual Studio Professional 2019
Win 10 Pro 64-bit
Akos Somorjai
You can use either, they are binary compatible. The one having the higher build number is the newer one.
Please note that newer devkits will be uploaded only to the new site.
Best, Akos
1 REPLY 1
Akos Somorjai
Best, Akos
