Developer forum
Clip Polyline behaviour in multiple cuts
Pertti P__sky
Hi GS
I found that the GDL ClipPolyline operation returns the right amount of cut polylines, but they are all the same ones. Have I missed something or is it a bug? I certainly wish this operation returned all cut polylines.
-You can move the polyline hotspots and see the results as offset lines compared to the original polyline,
My clip Polyline object
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Peter Baksa
Ok, let's talk about code.
This works in AC24. I didn't code regularization, but the input is as it should be. I tried it with another walkaround and the result was the same, so probably it isn't the cause. Maybe you forgot to increment the index in the result ID array when getting the results?
poChannel = initaddonscope ("PolyOperations", "", "")
preparefunction poChannel, "CreateContainer",         "inputContainer", ""
preparefunction poChannel, "SetSourceContainer",      "inputContainer", ""
preparefunction poChannel, "CreateContainer",         "resultContainer", ""
preparefunction poChannel, "SetDestinationContainer", "resultContainer", ""
dict polygon
polygon.isClosed = 1
polygon.useEdgeInfo = 0
i = 1
polygon.contour.edges.type		= 0
polygon.contour.edges.begPoint.x	= 0.0
polygon.contour.edges.begPoint.y	= 0.0
i = i + 1
polygon.contour.edges.begPoint.x	= 3.0
i = i + 1
polygon.contour.edges.begPoint.y	= 3.0
i = i + 1
i = 1
polygon.holes[1].edges.type		= 0
polygon.holes[1].edges.begPoint.x	= 1.0
polygon.holes[1].edges.begPoint.y	= 1.0
i = i + 1
polygon.holes[1].edges.begPoint.y	= 2.0
i = i + 1
polygon.holes[1].edges.begPoint.x	= 2.0
i = i + 1
preparefunction poChannel, "StoreDictPolygon", "polygon", polygon
iPen = 1
gosub "drawPolyOpPolygon"
dict polyline
polyline.isClosed = 0
polyline.useEdgeInfo = 0
i = 1
polyline.contour.edges.type		= 0
polyline.contour.edges.begPoint.x	= 0.0
polyline.contour.edges.begPoint.y	= -1.0
i = i + 1
polyline.contour.edges.begPoint.x	= 2.5
polyline.contour.edges.begPoint.y	= 2.0
i = i + 1
polyline.contour.edges.begPoint.x	= 4.0
polyline.contour.edges.begPoint.y	= 1.0
i = i + 1
polyline.contour.edges.begPoint.x	= 6.0
polyline.contour.edges.begPoint.y	= 4.0
iPen = 3
dict polygon : polygon = polyline
preparefunction poChannel, "StoreDictPolyline", "polyline", polyline
dim resultIDs[]
nResult = CALLFUNCTION (poChannel, "ClipPolyline", "polyline polygon", resultIDs)
add2 0, 0.01
gosub "drawResultPlines"
del 1
closeaddonscope poChannel
end
"drawResultPlines":
	for iResult = 1 to nResult
		dict polygon
		nVertices = callfunction(poChannel, "GetDestinationDictPolyline", resultIDs[iResult], polygon)
		iPen = iPen + 1
	next iResult
return
"drawPolyOpPolygon":
	! conversion to status-coded polygon
	dim outflat[]                   ! declare returned array
	polygon.hasClosingPoint = 0     ! always given without repeating the first point
	call "ProfileConverter" parameters  bProfileToPolyOp 	   = 0,
						bPolyOpDict        = 1,
						PolyOpPolygon      = polygon,
						returned_parameters	nOut,
									outflat
	! put results
	for i = 1 to nOut	           ! without closing point
		k = (i - 1) * 3
		put	outflat[k + 1],         ! x
			outflat[k + 2],         ! y
			outflat[k + 3] + 1      ! status
	next i
	! draw polygon
	pen iPen
	poly2_b NSP / 3, 1 + 2,
		iPen, 0,
		get(NSP)
return
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
7 REPLIES 7
Peter Baksa
Hi Pertti,
I didn't check your code, but the image shows that the hole walkaround is also counterclockwise.
Correct results are only guaranteed for regular polygons. Regular polygons should have each hole in a clockwise order.
Do you have the same issue when it is reversed?
Best practice is to regularize polygons before any operation if they depend on parameters.
Péter Baksa
Pertti P__sky
Ok, Peter. I have never noticed this clockwise rule. What I have seen is that the regularization takes place in some example pbjects.
Well, i'll try turning the clocks.
Thanks for the answer.
Pertti P__sky
Hi, I just drew the polylines clockwise, but the result is the same.
Pertti P__sky
Hi Peter!
You wrote:
"Regular polygons should have each hole in a clockwise order."
Ok, I tried to regularize the polygon with the dict.option output. It gave me only the outline, not the holes. Should it not do that?
As a result, the regularized outlines returned counterclockwise ( the red one) in both directions
I also changed the direction of the hole with no change in results.
So please check this function, or is there something I should knowhave not noticed?
BR Pertti
Peter Baksa
dict polygon
i = 1
i = i + 1
i = i + 1
i = i + 1
i = 1
i = i + 1
i = i + 1
i = i + 1
iPen = 1
dict polyline
i = 1
i = i + 1
i = i + 1
i = i + 1
iPen = 3
dim resultIDs[]
add2 0, 0.01
del 1
end
"drawResultPlines":
		dict polygon
		iPen = iPen + 1
	next iResult
return
						bPolyOpDict        = 1,
									outflat
	! put results
		k = (i - 1) * 3
			outflat[k + 2],         ! y
	next i
	! draw polygon
	pen iPen
		iPen, 0,
		get(NSP)
return
Péter Baksa
Pertti P__sky
Peter, thanks for solving the problem. The index in the result ID array was the reason as You mentioned.
I will carefully study Your code. These operations are not a peace of cake but I hope to master them.
Pertti P__sky
I noticed that in Peter´s code there were defined 4 outline points and 4 hole points in the "StoreDictPolygon" -definition while in the older "Store" definition it is supposed to give 5 points, the first and the last are the same.
It seems to work when You add the first point as the last point in the "StoreDictPolygon" -definition as well. Of course it is more convenient not to add the first point.
