Archicad C++ API
Column wrapped finish
ReignBough
Is there a way of getting the surface area of this wrapped finish on column? (Construction method: Wrapped)
The first thought that came to mind is the veneer surface area. But when I get the value, it is zero (0.00). This means that this finish is not considered as the column veneer.
~ReignBough~
ARCHICAD 26 INT (from AC18)
Windows 11 Pro, AMD Ryzen 7, 3.20GHz, 32.0GB RAM, 64-bit OS
abdelaziz
it would also be nice to be able to hang on to extremity of plating
AMD Ryzen 5950x
AMD RX 6750xt
AC27
ares997
Yes this is a couple of ways you can build a schedule that extracts the surface area from the column data, or you can go to the WINDOW (drop down menu)/Palettes/Element Information (near the bottom) and you should be able to get the surface area from that Palette.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
