GDL
Constant crash when changing pen attributes AC24
jc4d
I'm having a constant crash on my ac24 when I try to change the lines or fills in my custom gdl object. I have reduced to the minimum and still the crash is replicable.
Since yesterday I have sent the bug reports because ac force me to, here is the bug number:
AC24-2022-05-25-05-32-48-9545
It doesn't crash by one specific value, it is random when changing few of them.
https://www.youtube.com/watch?v=KuxCt8GlfxE
Here is the object: (I had to use wetransfer because the forum is not letting me upload the object)
https://we.tl/t-DFoKchflC2
The code is this if you don't want to download the object:
PEN penAttribute_1
FILL gs_fill_type
SET LINE_TYPE lineTypeAttribute_1
GOSUB 100
END
100:
poly2_b{5}       5,      2,      1,      3,     gs_fill_pen,     -1,
                   0,            0,            1,            0,            0,            1,            0,
                   0,            0,     33,
                   0,        -0.02,     33,
        0.05200001438073,        -0.02,     33,
        0.05200001438073,            0,     33,
                   0,            0,     33
RETURN
Juan
14 REPLIES 14
A_ Smith
Try to change parameter "gs_fill_pen" to its PEN type, not FILL ?
AC 22, 24 | Win 10
Thanks, sadly it keeps crashing here 😞
And lineTypeAttribute_1 should be a 'line' type parameter and not a 'pen'.
Thank you I missed that one too 😑
It keeps crashing to me.
hm... what about status code? why it is 33? what if you switch it to 15 and to -1 in the last row ?
AC 22, 24 | Win 10
That status came from dragging the poly from the floorplan to the 2d script.
I changed just in case and no difference 😞
I just downloaded your object and tried it in 25.
Once I fixed the parameter types it seems to be working just fine for me.
There is no perimeter on the polygon, but if you change it to ... poly2_b{5} 5,3,..........
there will be.
Thank you for checking it out, sadly I need to keep using 24 since is a multi office project and we need to keep using the same version.
And no matter what I try, even writting a new script on a blank new ac instance, it crashes or just freeze and I need to force quit ac.
it doesn't crash, at least after 30 sec of changing...
https://drive.google.com/file/d/17kSgy8x_cpVO_QsVwV9OE4Yuv71Lqj7H/view?usp=drivesdk
though i have 'spining circle' when choosing fills, but it doesn't crash
AC 22, 24 | Win 10
