Archicad C++ API
Contour lines in WALLBLOCK2
Joachim Suehlo
Does the WALLBLOCK2 command basically has no contour lines?
I tried it with frame_fill 7, as in POLY2_B, but its does not work.
Jochen Suehlo . AC12-27 . MAC OSX 14.4 . WIN11
8 REPLIES 8
DGSketcher
Legend
@Joachim Suehlo I have seen POLY2_B in GDL, where do you get "WALLBLOCK2" from, it isn't a standard listed function?
Joachim Suehlo
@DGSketcheryes, shurely:
DGSketcher
Legend
@Joachim Suehlo I'm due an eye test... 😬
New to me, never used it, but from the manual it is only considered as part of an opening object, much like the Wallhole command, so it may not function in a different object type?
This command can be used in the 2D script of door/window objects only.
You have probably done this but in addition to setting the FrameFill to 7, have you have set the edge status flags to 1?
Joachim Suehlo
Yes, I am using it in a window object, and yes, I set the edge flags to one.
See the example picture: Poly2_b and Wallblock2 have in the essential parts the same script.
Peter Baksa
No, it doesn't draw contours. It is very indirectly stated in the manual above wallhole2:
A correct solution [...] can be achieved by using the WALLHOLE2, WALLBLOCK2, WALLLINE2 and WALLARC2 commands.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
Bruce
One wonders why it includes the s1...sn at the end of the x, y if it doesn't do anything.
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5003 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Peter Baksa
Those are for additional status codes (arcs).
Péter Baksa
Bruce
I see.  Thanks Peter.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
