Archicad C++ API
Convert from string to length
JGoode
is it possible to convert a string to a length?
Thanks
ArchiCAD 23
Windows 10
DGSketcher
Legend
In GDL yes. Look up the obviously named SPLIT command. 🙄 To be fair it does a good job, it's just not as immediately obvious as something like "StrToNum" which doesn't exist.
DGSketcher
Legend
DGSketcher
Legend
... Unless you were after the length of the word on screen which is STW, or the number of characters which is STRLEN?
Thank you very much! I was aware of the SPLIT command but didn't know that it achieved what I was after.
ArchiCAD 23
Windows 10
