Archicad C++ API
Create basic AddOn for Archicad 22 in Visual Studio
Hello. Please very good if you can help me. I want to create an AddOn for Archicad 22 that is similar to Eptar Reinforcement as design.
I installed Visual Studio 2017, Archicad 22, I have the Archicad developer key, but I can not compile a code and install it as an addon in Archicad.
I want to learn how to make a very simplified addon, to see in Archicad that a window with a function opens and to go.
I looked at c ++ tutorials, c # .. but in vain.
I saw the extension of an addon is *. APX. do I have to do a Setup.exe for addon or how to do it? Interface in Archicad I create in C #?
I've been trying to see the examples from Archicad, but I get errors.
Some print screens would be very useful if you can not do a basic tutorial.
Please be very nice if you can help me. Bogdan
Sorry for my bad enlish i hope you understand
13 REPLIES 13
Ralph Wessel
Mentor
Try making that:
const GSSize    hwLen  = static_cast<GSSize>(strlen (hwText) + 1);
Ralph Wessel BArch
the compilation works fine but I couldn't see the Hello world on Archicad.
Menu loaded, but When I click it, nothing happened.
When I finished the compilation first time, the tool showed me a warning. Second time, it didn't.
Ralph Wessel
Mentor
That's a link warning, but you can ignore that one - it's only advice (and irrelevant in this case). It will only show up when you rebuild following a change.
Ralph Wessel BArch
