GDL
Curved Wall Parameters for Labels and Column Section for Labels
Joachim Suehlo
I am looking for a Global Variable which defines the radius of a curved wall. I want to follow with a fill (defined in a label) the outer contours of the wall.
Something similar for a column: the Global Variables for the outer contours for normal columns or for columns with a profile.
Joachim Suehlo . AC12-27 . MAC OSX 13.5 . WIN11
GDL object creation: b-prisma.de
1 REPLY 1
Peter Baksa
there is LABEL_ASSOC_ELEM_GEOMETRY for walls. This is the reference line only, not enough data for a fill. Maybe you can do something with WALL_SKINS_PARAMS, but there is no information about the reference line offset.
Note that using this makes sense only from a label which has no pointer, as AC moves the drawing if there is a pointer.
COLU_SEGMENT_INFO gives general cross-section information, but no position, direction, rotation.
Please make a feature wish to let GS know that drawing on the labelled objects would be useful.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
