GDL
Doesn't the 3D script take the master scripter's variable values? In the 2d script, it takes a value
LeeJaeYoung
In the 2d script, it takes a value.....
Shouldn't I use an if statement?
AC27 on window 11
14 REPLIES 14
LeeJaeYoung
WALL_FLIPPED doesn't work in 3D
WALL_FLIPPED doesn't work in 3D - Graphisoft Community
I still don't understand.
Passing the value from Master to wall_flipped as another variable does not work.
The conclusion seems to be that all values should be done in master and only those values should be used.
I spent the whole day on this today.
I believe that bugs should be fixed as soon as possible.
Master script
IF ((SGN(SYMB_ROTANGLE) = 0) & (WALL_FLIPPED = 0)) Then
    npen = 1
ENDIF
IF ((SGN(SYMB_ROTANGLE) = 0) & (WALL_FLIPPED = 1)) Then
     npen = WALL_SKINS_NUMBER
ENDIF
3d script
print "xx"
print npen
TEXT 0.3, 0, npen
xx (WD - 003 | 15AAE85E-ECC7-48F2-9214-37F58DDBB692)
1 (WD - 003 | 15AAE85E-ECC7-48F2-9214-37F58DDBB692)
And this was also tested at 25.
Can not be done.
Value does not change.
How can i solve it?
AC27 on window 11
One of the doors I wrote for composites I figured this out, but I don't use composite walls with more than one skin anymore so that door is somewhere in my archives.
Assuming I understand what you are after it is possible but it will be a minute before I have time to go digging.
i used the WALL_MAT_A, WALL_MAT_B system to identify outside vs inside of walls (before Archicad 22 introduced WALL_FLIPPED variable)
it is more complicated than "WALL_FLIPPED",
but
the "WALL_FLIPPED"  does not work in the 3D Window/Elevation window...
but does work the 2D window.
I have been using ArchiCAD continually since ArchiCAD 4.5
Member of Architalk since 2003, but missed the migration from Architalk to Graphisoft Communities. Melbourne, Australia
Where should I look to learn how to identify the exterior and interior of a wall with WALL_MAT_A WALL_MAT_B? Is there a gsm where I can see the code?
AC27 on window 11
Guru
https://community.graphisoft.com/t5/Developer-forum/WALL-FLIPPED-doesn-t-work-in-3D/m-p/257116/highl...
thank you. ^^
I will study hard.
AC27 on window 11
Hopefully that is what you were looking for
It is judged that WALL_MAT_A is not related to WALL_FLIPPED, but rather related to SGN (SYMB_ROTANGLE).
Therefore, it seems that WALL_MAT_A value cannot determine whether it is inside or outside in 3D.
I don't understand the code you gave yet, but it seems there is an IF statement option, and I'm thinking of turning it on in 3D.
Am I wrong?
AC27 on window 11
Guru
I believe I have determined inside from outside using WIDO_REVEAL_SIDE.
	IF WIDO_REVEAL_SIDE = 1 then
			WALL_MAT = WALL_MAT_A
		else
			WALL_MAT = WALL_MAT_B
	endIF
