2020-07-13
11:58 PM
2021-09-15
02:57 AM
Noemi Balogh
2020-07-14 03:04 AM
juliencuadra wrote:Anything starting with ^ in a menu item is specifying a context in which that menu is relevant. For example, "^E3" means "enabled in 3D window". You can find documentation on this here:
What is this part : 1. ^ES^EE^EI^E3^ED^EW^EL ?
juliencuadra wrote:The best approach generally is for the user to select some elements first and then select a menu to perform some action on the selection. That's how most tools already work in Archicad.
What is this part : 1. 2. How do you interact with elements already placed in your project?
- What function in the API let the user select some elements on the floor plan, or what is the general process to ask the user to select some elements
- If I want to do that automatically, how does the Add-On can search through the project to find zones in it ?
auto selectedZones = plan.getSelection({Drawing::Filter::isEditable, Zone::ID});GS' sample code for collecting elements is much more verbose:
GS::Array<API_Guid>& inds GSErrCode err; API_SelectionInfo selectionInfo; API_Elem_Head tElemHead; GS::Array<API_Neig> selNeigs; err = ACAPI_Selection_Get (&selectionInfo, &selNeigs, true); BMKillHandle ((GSHandle *) &selectionInfo.marquee.coords); if (err == APIERR_NOSEL) err = NoError; if (selectionInfo.typeID != API_SelEmpty) { // collect indexes of selected dimensions UInt32 nSel = BMGetHandleSize ((GSHandle) selNeigs) / sizeof (API_Neig); for (const API_Neig& selNeig : selNeigs) { tElemHead.typeID = Neig_To_ElemID (selNeig.neigID); if (tElemHead.typeID != API_DimensionID) continue; if (!ACAPI_Element_Filter (selNeig.guid, APIFilt_IsEditable)) continue; tElemHead.guid = selNeig.guid; if (ACAPI_Element_GetHeader (&tElemHead) != NoError) continue; // Add dimension to the array inds.Push (tElemHead.guid); } }
2020-07-14 03:44 AM
