2023-05-18 02:36 AM
Can I create a shape in GDL that looks like a truncated cone with a slope on one side only like attached image?
Both the upper and lower faces of the cone are circles.
Solved! Go to Solution.
2023-05-18 03:06 AM
You would have to use the SWEEP that allows you to scale the polygon along the path or RULED that allows you to connect two or polygons with the same number of nodes.
2023-05-18 06:06 AM
Thank you fou answering.
I have successfully created the intended shape using the sweep command!
Thank you!!
Tamura
