GDL
GDL:CONE:truncated cone with a slope on one side only
iu-tamura
Can I create a shape in GDL that looks like a truncated cone with a slope on one side only like attached image?
Both the upper and lower faces of the cone are circles.
You would have to use the SWEEP that allows you to scale the polygon along the path or RULED that allows you to connect two or polygons with the same number of nodes.
Thank you fou  answering.
I have successfully created the intended shape using the sweep command!
Thank you!!
Tamura
