GDL
GDL COOR{3} with PLACEGROUP command
concepsys
I am creating a geometry by creating a GROUP.
Inside this group I have for..next loop that CALLs a geometry.
I want to apply a texture over this construction, but I can't. No matter what I try the texture (that I placed in the beginning of the GROUP is still and won’t change.
I tried using COOR{3} inside the group (between GROUP and ENDGROUP commands)
I tried after ENDGROUP command
I tried after PLACEGROUP command
but cant control the texture.
How can I solve this?
(By the way, I am working in Archicad 22 to make sure they become compatible with all later Archicad/GDL versions. Could this be a problem that has been solved on a later version?).
Thanks in advance.
10 REPLIES 10
concepsys
Sorry for my late reply. I hat to deal with other projects and only yesterday got back to this one.
I'd like to thank all the help that I got on this theme, specially from @runxel that took a lot of his time to help me with valid yet more complex solution. Your GDL knowledge is very impressive and if you don't mind I may bother you again in the future.
I marked Péter Baksa's post as the solution because in fact, althoug my inital question was itself more complicated than needed, his solution was the one that I ended up using, just because it was an easy solution for my actual problem, allowing to keep the project centralized in a file that calls simple macros and allows an easier way to manage diferent unique randomly shaded elements through different composition geometries. The result was great!
Again, Thank you all.
