Developer forum
GDL: GLOB_CUTPLANES_INFO
Legend
Please correct the GDL Reference Guide; GLOB_CUTPLANES_INFO[1] returns the zzyzx minus the cutplane height, not the cutplane height itself.
Win10 | R5 2600 | 16GB | GTX1660
4 REPLIES 4
BPETER
Agreed.
Did a small object that shows the FPCP height in floor plane, i resolve this issue by adding the object elevation - GLOB_CUTPLANES_INFO[1] + GLOB_ELEVATION
Use  + GLOB_CSTORY_ELEV - GLOB_HSTORY_ELEV. This will give you the height from the FPCP of your current story, rather than is being static to the objects zzyzx value.
https://community.graphisoft.com/t5/Design-forum/GLOB-CUTPLANES-INFO-1-inconsistency/m-p/304361#M154...
It`s working okay, i used it to display the FPCP value of a floorplan, so its need to be a static value that is not influenced by the objects elevation (object is just there to show the value in floorplan-  like a label). Adding them together made it work properly, but i will do some test with your suggestion.
Peter Baksa
You meant the object's placement height? ZZYZX is the object's height, that is not related to it.
The placement height is the origin of GDL objects, GLOB_CUTPLANES_INFO is relative to that.
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
