Developer forum
GDL - How can I get user-defined properties?
Yohei Sekiguchi
Hello.
I can retrieve the core and IFC properties with Application Query Options.
But I cannot retrieve the user-defined properties with this query.
The reference guide describes it as follows.
These queries don’t return user-defined properties.
Then how can I get user-defined properties?
Thank you🙂
runxel
Mentor
Short story: You can't.
Long story: You can, if you're a label.
Then you can do "REQUEST('Property_Value_Of_Parent',....)"
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
runxel
Mentor
Yohei Sekiguchi
Thank you for your reply, runxel.
Now I can retrieve user-defined properties with my label.
there is one "but"...You can map Your property to IFC property...and then use the routine You used for it.
