Developer forum
GDL: User Input - "Can't Find Macro" - Return
Hero
Hi all,
I have a macro call in which the user can inser their own symbol objects, and I was wondering if there was a way to detect whether the inserted name exists so that I can ignore the input if it does not whilst giving a notice about it. At the moment it just fails to generate which is highly inconvenient.
Ling.
Win10 | R5 2600 | 16GB | GTX1660
4 REPLIES 4
DGSketcher
Champion
Could you use OPEN to test for the file presence and use the return values followed by CLOSE?
Apple iMac macOS Ventura / AC26UKI (most recent builds)
folder = OPEN (called_object, "c:", "FILES")
Any idea how you would point that at the loaded libraries?
Hm. Found Runxel's thread about this...
Similar thread
Hero
@DGSketcher - Could you use OPEN to test for the file presence and use the return values followed by CLOSE?
Figured out how to use the text I/O to query if the file exists
channel = OPEN ("TEXT", marker_call, "library")
IF marker_call # "" & channel # -1 then		!Name inserted, name exists (actually > -1)
		MUL2 marker_height * (-10) * GLOB_SCALE, marker_height * 10 * GLOB_SCALE
			CALL marker_call parameters ALL,
					penAttribute_1		=	penAttribute_1,
					penAttribute_2		=	penAttribute_2,
					penAttribute_3		=	penAttribute_3,
					penAttribute_4		=	penAttribute_4,
					fillAttribute_1		=	fillAttribute_1,
					fillAttribute_2		=	fillAttribute_2,
					lineTypeAttribute_1	=	lineTypeAttribute_1,
					lineTypeAttribute_2	=	lineTypeAttribute_2
		DEL 1
		TEXT2	0,	0,	channel
	else
		IF i = 1 then
			TEXT2	0,	0,	"Marker Name Not Found"
		endIF
endIF
Ling.
Hero
Hm. The OPEN command does post around 80 lines to the Session Report saying that the file is not found which is a bit excessive...
