2021-11-02 02:19 PM - edited 2021-11-02 02:35 PM
What could be the problem with value lists, when trying to return parameters from macro to parent object with END param_name? Same happens with EXIT param_name. Parameters with value lists are disabled. (Archicad 23 / Win)
It happens even with simpliest object possible. Anyone else had this problem?
Same problem happens in parent object, while CALL "macroname" PARAMETERS ALL RETURNED_PARAMETERS test
Never had this problem before...
EDIT: Same happened even with AC16. Am I missing something?
2021-11-02 10:17 PM
If You place end in master script... it will end the processing...
place the values command before this end command and it will work.
