GDL
GLOB_SUN_AZIMUTH shows default value
greg_lupo
I would like to read GLOB_SUN_AZIMUTH value and put it to array parameter then change sun position and again add new value to an array. Master script looks like this
if glob_ui_button_id = UI_SET then
count = vardim1(list)
 list[count+1] = GLOB_SUN_AZIMUTH
parameters list = list
endif
When ui_button (with id = UI_SET) is pressed only default value (240) is placed in "list" array but when use e.i
rotz GLOB_SUN_AZIMUTH
block 1,1,1
rotation is ok.
Why current value is not passed?
8 REPLIES 8
http://gdl.graphisoft.com/reference-guide/fly-through-information
Does not work in Parameter script...only 2-3D and UI.
Piotr
Peter Baksa
The camera tool can store different sun positions, and GLOB_SUN_AZIMUTH will be updated when rendering the animation path.
Are you trying to do something different?
Péter Baksa
Software Engineer, Library as a Platform
Graphisoft SE, Budapest
greg_lupo
Piotr
Yes I know that. script was put into Master.
greg_lupo
Yes I want to make an object that stores several sun postions and draws 2D symbol with cpecific rays.
In 3D it supose to produce 3D rays. Then I want to use it in Grasshopper where rays will be converted to vectors which will be put in a middle of selected windows. Rays will have "infinite" length so I want to use them to find collisions with surrounding buildings.
runxel
Legend
That actually doesn't matter.
The master script in GDL is kind of a "global" script in that way, that you can put any command there, it will mostly executed in the right context.
This also means, your script won't work.
What you want to achieve is not possible, the user will have to input the sun positions manually, if you want to have them all at once.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
greg_lupo
I understand. hmm pity. Now it works manually. user rotate hotspot2 in actual azimuth position of sun and drag hotspot in 3d to get actual Altitude. Then in UI can add this two values to array.
I hoped I could avoid using hotspots.
Peter Baksa
Hi greg_lupo,
Maybe you can skip using hotspots and set up the sun position on the UI.
ui_outfield GLOB_SUN_AZIMUTH, 0, 0, 100, 20
will show the current value on the UI, give an infield next to it where the user can repeat it as input. I know its lame but the closest workaround we have.
Péter Baksa
greg_lupo
Yes, looks simpler than moving hotspots. Will try that.
