2004-12-04 07:02 PM
Date/Time: 2004-12-04 18:05:09 -0800 OS Version: 10.3.6 (Build 7R28) Report Version: 2 Command: CodeWarrior IDE Path: /Applications/Metrowerks CodeWarrior 9.0/Metrowerks CodeWarrior/CodeWarrior IDE Version: ??? (???) PID: 583 Thread: 2 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000 ... Thread 2 Crashed: 0 ConvertGRC_90 0x070bb548 Write_Error__FPclUc + 0x1e8 1 ConvertGRC_90 0x070bb7ac CL_Error__FPc + 0x24 2 ConvertGRC_90 0x070bb064 InitMacBuffer__FPclc + 0xe4
2004-12-06 05:24 PM
2004-12-09 01:16 AM
2005-02-09 02:30 AM
Karl wrote:Karl,
As a workaround, I've found that if I open a Windows grc file in Word on the Mac and then immediately save as text, then the CR's are stripped off and all works fine.
2005-02-09 11:38 AM
Ralph wrote:Aha! Thanks, Ralph.
You can easily change the text file type (Mac/DOS/Unix) from a menu in the toolbar at the top of every source-code window in CW (and many other text editors). See the attached image.
