GDL
Get Layout Custom Field Info
Bruce
Is there any way to retrieve the content of Custom Fields in the Layout Info Scheme?  I've tried copying and pasting the autotext (in this case <LAYOUTCUSTOMPAR8>) into the TEXT2 command, but that doesn't work for custom fields.
REQUEST ("HomeDB_info"... doesn't give me the data I'm looking for either.
Is there some other way to retrieve (in GDL) the content of these scheme fields?
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5003 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
2 ACCEPTED SOLUTIONS
AllanP
I think thats the one....
or it could be another array...
dim issuescheme[][]
issuescheme =GLOB_ISSUE_SCHEME
text2 0,0,issuescheme[2][7]
I have been using ArchiCAD continually since ArchiCAD 4.5, 4.5.5, 5, 5.1, 6, 6.5, 7, 8, 8.1, 9, 10, 11, 12, 13, 15, 18, 21, 22, 25, now testing 27
Member of Architalk since 2003, but missed the migration to Graphisoft.
(where have all my original posts gone?)
Yves
You can download an example object here https://gdl.Graphisoft.com/tips-and-tricks/revision-data-in-gdl
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
AllanP
dim issuescheme[][]
Yves
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Bruce
That's what I'm after.  Thanks AllanP & Yves.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
