Archicad C++ API
How I can get polygon of the not square window in the wall?
I need to get polyton of the rounded or other not square windows in the wall.
Where I can it find?
Thank You.
Ralph Wessel
Mentor
Our approach has been to examine the 3D model faces of the wall. If you cut the wall face with the window against the wall face without the window, the difference is the opening shape.
Ralph Wessel BArch
Into the AC library there folder which is called "special windows"
Into this folder there is a parametric window with 3 sides or more
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
I'm know how place that windows.
But I need to get it's form by API C++.
Ralph Wessel
Mentor
Ralph Wessel BArch
