Archicad C++ API
How can I find any Example ( or source code ) ... ?
I found Automatic Dimension.apx in Add-on\Standard folder. How can I find any Example ( or source code ) of it.
( or example about Creating Dimension ...)
Thank you.
Hemmachr.
1 REPLY 1
Ralph Wessel
Mentor
The source code for standard ArchiCAD add-ons isn't usually open-source, and I doubt it is available anywhere.
I assume you've looked through the examples with the API dev-kit? I don't remember an example which creates a dimension, but the principles involved in creating any element should be relevant.
Take a look through the documentation covering the creation of elements, and look at the data structure 'API_DimensionType' for a start.
Ralph Wessel BArch
