Archicad C++ API
How can I modify the name of menu item in the code?
Hi.
Because there is a error(illegal character) when I set the longer chinese character in grc file.
So is there any method that can dynamicly modify the name of menu item in the code ?
Akos Somorjai
See APIIo_SetMenuItemTextID. You can find an example in Interface_Functions.cpp in the devkit.
Best, Akos
Akos Somorjai
Best, Akos
Best, Akos
Thanks.
