2020-06-16 10:43 PM - last edited on 2022-09-26 10:53 PM by Daniel Kassai
2020-06-16 10:59 PM
AUTOTEXT GUIDEThis suggest to me that if you have a hidden string Parameter you could predefine it with <CURRENTISSUEID> and then reference that parameter in your scripts. It's a while since I did any serious GDL so it's just a suggestion that I haven't actually tried.
It’s not part of GDL itself. ARCHICAD will substitute all references to autotext fields in whatever GDL output it finds them. For example, if you write <PROJECTSTATUS> in the parameter string of a text2 command, ARCHICAD will nicely replace it with the actual value. All this is invisible to GDL – consequently the size and other attributes of the text are not measurable.
2020-06-17 03:21 AM
2020-06-17 03:23 AM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2020-06-17 01:01 PM
2020-06-17 02:15 PM
