smgyblnt wrote:
Hello! Thanks for the fast replies!
I was wondering, whether I could create a simple object for folding marks, in order to be able to fold the plotted plans to A4 sizes. And the aim was just to be able to update the marks (divison number), once the roll size (29, 42, 59,4, etc), or the roll lenght changes, and avoid drawing the marks manually each time a new layout is created (in multiple project files as well).
Are you adjusting your master size every time you want an new page size?
If so there is no need.
Set up a master for each page size - I also do one for portrait and landscape.
So if you need 3 different page sizes, you will have 3 masters (or 6 if you go portrait/landscape).
Now you add the fold marks to the master and that is it - job done.
Now when you set your layouts up, you just choose the master (and hence page size and orientation) that you want to use.
And it already has the fold marks.
If you need to change the page size, just swap the mater for that layout.
So now, as you are not adjusting the master size, you do not need to adjust the fold marks.
Set and forget.
