Developer forum
How to call ACAPI_Automate(APIDo_SaveID) inside ACAPI_CallUndoableCommand scope?
n_mihaylov
Hello guys,
I call a function in ACAPI_CallUndoableCommand scope and inside this function I call ACAPI_Automate(APIDo_SaveID) and ACAPI_Automate is not working:
ACAPI_CallUndoableCommand("Import Files", [&]() -> GSErrCode { ImportFiles(); return (0); });
void ImportFiles()
        ACAPI_Automate(APIDo_SaveID);
Is there a way to get out of this scope or I have to call it outside ImportFiles?
Tibor Lorantfy
APIDo_SaveID is not allowed to be called inside ACAPI_CallUndoableCommand scope.
Sorry, you have to call it outside.
Regards,
Tibor
Tibor Lorantfy
Regards,
Tibor
n_mihaylov
In order not to open a new topic for these automated functions, how can I open a new project with the "rectangle area" in the center? I open a new project using the example and don't have it:
        API_NewProjectPars npp;
	BNZeroMemory(&npp, sizeof(API_NewProjectPars));
	npp.newAndReset = true;
	npp.enableSaveAlert = false;
	GSErrCode err = ACAPI_Automate(APIDo_NewProjectID, &npp);
If I manually open a new project, ARCHICAD 23 Template.tpl is choosen and everything is OK.
How can I choose this template with the automated function?
MOREH Tamas
Hi!
You are right it is currently not possible.
I register it in our issue tracking database and we will implement as soon as we can.
Thank you for the report.
