2018-03-15 08:47 PM
const GS::UniString a = L"xxx";or
DGTreeViewSetItemText(dialogID, itemID, CS,L"xxx");It is no problem if I develop in windows
2018-03-16 04:21 AM
GS::UniString a(u8"xxx", CC_UTF8);
2018-03-26 05:29 AM
#ifndef SL std::string ToUtf8(const std::wstring& widestring) { size_t widesize = widestring.length(); if (sizeof(wchar_t) == 2) { size_t utf8size = 3 * widesize + 1; char* utf8stringnative = new char[utf8size]; const UTF16* sourcestart = reinterpret_cast<const UTF16*>(widestring.c_str()); const UTF16* sourceend = sourcestart + widesize; UTF8* targetstart = reinterpret_cast<UTF8*>(utf8stringnative); UTF8* targetend = targetstart + utf8size; ConversionResult res = ConvertUTF16toUTF8 (&sourcestart, sourceend, &targetstart, targetend, strictConversion); if (res != conversionOK) { delete [] utf8stringnative; throw std::exception("La falla!"); } *targetstart = 0; std::string resultstring(utf8stringnative); delete [] utf8stringnative; return resultstring; } else if (sizeof(wchar_t) == 4) { size_t utf8size = 4 * widesize + 1; char* utf8stringnative = new char[utf8size]; const UTF32* sourcestart = reinterpret_cast<const UTF32*>(widestring.c_str()); const UTF32* sourceend = sourcestart + widesize; UTF8* targetstart = reinterpret_cast<UTF8*>(utf8stringnative); UTF8* targetend = targetstart + utf8size; ConversionResult res = ConvertUTF32toUTF8 (&sourcestart, sourceend, &targetstart, targetend, strictConversion); if (res != conversionOK) { delete [] utf8stringnative; throw std::exception("La falla!"); } *targetstart = 0; std::string resultstring(utf8stringnative); delete [] utf8stringnative; return resultstring; } else { throw std::exception("La falla!"); } return ""; } #ifdef _WIN32 #define SL(str) str #else #define SL(str) ToUtf8(str).c_str() #endif #endif const GS::UniString a = SL(L"xxx"); // This will compile well now.You may move the code into a separate header file and include it everywhere you want to initialize UniString with a string literal. Just remove the last line with a comment.
#include "sl.h" const GS::UniString a = SL(L"xxx"); // This will compile well now.
2018-03-26 10:25 AM
chebum wrote:A few observations:
UniString is implemented differently on Mac: it stores characters in UTF-8 encoding on Mac(e.g. 1-byte per character). On Windows it uses wchar_t which is 2-bytes per character. Thus const GS::UniString a = L"xxx"; will compile on Windows, but will fail on Mac. Graphisoft changed implementation of UniString somewhere between AC15 and AC21. In older versions it used wchart_t.
All C strings (char *, char []) are now UTF-8 encoded.2) Text encoding is not the same as the number of bytes consumed by a character. Many different encodings will use the same number of bytes, but are not equivalent. Constructing a UniString from wchar_t only works on Windows because it's commonly assumed to be UTF-16. It's a bad idea if you intend to write cross-platform code.
chebum wrote:I'd strongly recommend using the mechanisms provided by GS. Writing your own methods for solved problems just wastes time and opens you up to more bugs and future migration problems.#include "sl.h" const GS::UniString a = SL(L"xxx"); // This will compile well now.
